gswan
Siegfried Meier said:So ya, just like I mentioned before, R55 and R54 still do nothing. I have gone through the calibration process for Q bias, which is also messed up and doesn't react like my other pushbutton units did, but I cannot continue without solving this. There are currently bourns multi turn pots in there, is that a bad thing? No matter how many turns, these 2 pots do absolutely nothing...likely due to the same issue I'm having with the metering when I do Q bias. Something is just not right with the meter board, or meters.
I'm almost ready to pack it in on rotary versions, so far they suck to me. Pushbuttons all the way.![]()
The shape and style of switches uaed to select parameters have no bearing whatsoever on calibration and testing of the unit. It's you own lack of understanding of what you are doing.
Did you perform the calibration of the GR FET bias correctly?
Did you verify the bias conditions on the BJT's?
Did you check that your supply rails are stable and correct?
Did you check that your components and wiring are correct?
Do your meters have internal diodes or do they require external circuitry to work as VU meters?
With GR displaed can you run a signal through the unit and observe that it is undistorted and that the gains of the input and output stages are correct?
