intercorni
Member
Hello,
where can I buy a resistor 1K1 / 1W?
Cornel
Cornel
danjpiscina said:i'm having the same problem with my rev F board. what did you end up doing to fix this? which transistors did you need to replace? if anyone has any ideas, they would be much appreciated! thanks,
dustbro said:danjpiscina said:i'm having the same problem with my rev F board. what did you end up doing to fix this? which transistors did you need to replace? if anyone has any ideas, they would be much appreciated! thanks,
Replace your BD135/BD136 transistors
dustbro said:Replace your BD135/BD136 transistors
skal1 said:ok have not got a scope but i can do some science with sound card and music program, at what point dose the signal enter the gr amp gswan ?..
skal1 said:ok i understand that ,so assume that ponit 22 gets the signal from pin y is that correct ?
ok 1 more ? , is the meter switch 4 pole 3way or 3pole 4way.
skal1 said:hi ,still no change with this thing , what are the voltages for q1 and q2 theses should be bf245 ,right
