seavote
thanks that exactly the type of direction i need!! i have no bench psu. could i just hook up 3 9V batteries and introduce them to the circuit after the regulator??
seavote said:thanks that exactly the type of direction i need!! i have no bench psu. could i just hook up 3 9V batteries and introduce them to the circuit after the regulator??
seavote said:when i replaced the 7824 last time i connected wire to the pads and the wires to a 3pin female molex connector that accepts the regulator so i could mount it offboard on the case since it was getting hotter than i expected.
gyraf said:Normal inputs to ground.
Do NOT normal outputs to ground - shorting output at high levels can probably seriously disturb the output stage.
Jakob E.
gswan said:What is the nature of the distortion? Clipping? Crossover? Harmonic?
Run a pure sine wave through the device and see if there is any distortion at the output under different signal level conditions. You need to do this with a scope and use subtraction to remove the input sine wave from the output to view the distortion artifacts.
gswan said:Q2 is a BJT, it does not have a Drain. It has B, C and E pins. Q1 is a JFET and has G, D, S pins.
What signal do you have on the top of the Input pot?
If it is still looking distorted there then check the DC level at pins 3 and 5 of the op amp (they should be the same, around 15V). Check the signal at pin 7 of the op amp too.
