Orson,
You must have just changed something for the worse on your output transformer. You JUST had 6.8V(previous page) on the output XLR with the FET pulled and now you have 3.2V.
Go back and see what you just did to that output transformer!
What is good to see is that things are looking much better gain-wise when you put the FET back in(maybe something wasn't seated before, or the Qbias trimmer was set way wrong). Everything in terms of gain stays about the same, which is good, except you need to fix your OPT so it works like it did before.
That dc voltage on the release wiper should be a NEGATIVE number(black probe to ground). Go back and verify that. While you are measuring there, run the Qbias trimmer from one extreme to the other, note the voltage at each extreme, and leave it set for the highest negative voltage(should be better than -2Vdc).
The idea will be to reduce this negative voltage just a a tad with the Qbias trimpot until the output falls just 1db. This puts Q1 right at the beginning of its conduction.
But leave the Qbias trimpot at max bias for now and get that OPT sorted out so you get back your ~6.8V with the FET installed. Just back up and carefully go through your OPT wiring and hopefully you'll find the error. Power down and use your ohmeter to verify jumper connections and trace cuts, if needed.
If you are confused, let us know. I think we're close. Just stay focused and bear with me a little more.
Dean
Dean
