No idea. Sometimes people like to find out what's wrong. Often it's like a detective book. But that's just my speculations.I wonder why no one has chimed-in on this, This post has over 9k views, and only a few people have posted here including myself???
Ok I am a space, I took the output voltage in respect to ground when I should have taken it across the output molex connector,, getting 0db now with R15 around mid level.Output Transf is wired correctly
Ok I will let you know how it goes tomorrowTry PN3640. BF824 might be the problem
I am still a little confused you say: Apply the 1kHz 0dBu test tone to the compressor input. Adjust the Threshold control so that the module compresses 9 dB?Do you have C90 installed and not shorted out? If installed, try replacing it with a short and see what happens.
What's your chopper transistor?
Attached is what I get when I run your track through my unit. Compression LEDs show ~6-10dB of compression
As for calibration, you can check compression level by engaging either bypass or 1:1 ratio. You get the increase in level in bypass. The difference between this level and the level with compression engaged is your gain reduction. You need to adjust your generators so that you get 1dB for a first generator and 9dB for a second. This makes switching between signals easier and you can calibrate your meter faster.
