Sorry...tfp said:Hi Ilfungo,
I already shared the meter scale some pages ago. I made the scale myself and printed it on some light yellow paper!
all the best!
plektra said:I finally finished debugging, fixing and calibrating the first unit (I also had broken TL071s). Sound is pretty fantastic
I'm still having some issues with the another channel, input signal becomes too hot at some point. No matter how do i turn the knobs, above threshold led is always lit. I've swapped all ICs between the two units and gone through basicly all solderings but the problem persists. I also tried isolating the board from metal riser pads, but no bonus. Any tips where I could find the point of failure?
trampo said:Hi all
I have the same problem as plektra, one board no problems other board even with following the calibration procedure I cant get the above and below led to the off position, the above led is always on.
Any suggestions would be much appreciated.
Trampo
sr1200 said:Hey, ive been using my dual CLX for a few projects recently, and i started to notice a weird buzz (the paz meter shows it as a small spike at 70hz and from 10K up theres a weird wavy signal happening) ITS VERY minute, but would love a way to kill it if possible. Any thoughts?
plektra said:We debugged this unit yesterday and there seems to be something strangely wrong with the another board. By an accident we discovered that the channel works well when following connections exist: oscilloscope measuring both input and output voltages between hot and cold wires and there is something connected to the output (in this case, output of CLX-VU was connected to a mixer input). When anyone of these is removed, signal is multiplied at an early stage so that above led is always lit. Odd is also that when one of the connections is removed, manipulating the output signal by turning threshold or ratio pots, it also affects the input signal measured straight from the input XLR connector...
The other channel is working and can be calibrated, so we swapped the boards (and also tried with one channel powered at a time), but the problem goes along the board, so this eliminates the possibility of broken/shorting wiring. Also it is not a grounding issue, because the another board works well with the same grounding schema. All chips have also been swapped between the units, problem persists.
I think next I'll go through the solderings once again and search for any possible solder bridges or dry joints. Any other ideas?
sr1200 said:Followed the build manual to a tee, so however the grounding is there. It DOES increase with output gain. When set at 0 its gotta be below -60fs. But if i put a limiter on my mix bus it becomes pretty noticeable. (first i thought my monitors were humming since i recently re-located my power amp to the next room, thought maybe the cable run was too long) Again, not a huge deal since it is REALLY low (but i tend to mix pretty low which brings my noise floor into play). Has become a go-to comp on kick drum lately. I've been told to use it on snare which i've gotta try soon, but its gonna take a lot to convert me from my 1176 revD's.
abechap024 said:Super strange....hmmm so the problem follows the board? I would look for any solder problems/shorts, like you mentioned.
plektra said:abechap024 said:Super strange....hmmm so the problem follows the board? I would look for any solder problems/shorts, like you mentioned.
Just went through all solder points but the problem still persists. If I could read the schematics any better, I could maybe follow the signal path and try to find any broken passive components.
