abechap024 said:sr1200 said:Just an update on my diagram above. Just finished building it (the thing in the drawing). Works perfectly!! CCW is INPUT. CENTER is GR. CW is OUTPUT.
Awesome, and good diagram in case anyone else wants to use a rotary switch.
horizonsound said:Hi Abe (and everyone).
Recently completed the assembly of two units, and true to form I rushed and did not read the manual, powered it up and blew the TL071 chips to pieces. Really, they both shattered. My rail voltages were -8/+27. After adjusting and replacing the TL071's, I'm having problems calibrating the RMS section. There is only a very feint waveform at the test point, which is not affected by the signal put onto the input of the unit.
I suspect that all other chips are damaged as well, so have put in an order to replace them all.
Only issue is, that the CA3083 chips are near impossible to find. Everywhere appears to be out of stock or discontinued. Help! Abe, where did you source yours from???
Anthony.
horizonsound said:Of course. How silly of me.
Too easy.
Anthony.
abechap024 said:Yea I've done that before and it sucks. I need to get a stash of them!
horizonsound said:abechap024 said:Yea I've done that before and it sucks. I need to get a stash of them!
Picked up a few from a seller in the UK. Now just waiting....
Could you confirm a few things with the RMS calibration for me, just to make sure?
-60dB level signal, is equivalent to about 0.002Vp-p? My signal generator only gives Vp-p
The signal is then applied to pins 1 (ground) and 2 (hot) of the input connector.
At this point, I get an almost sawtooth wave out at the Offset Pin, which can be slightly adjusted by R36. Adjusting the signal generator - even turning it off - make no change to this.
Still have to replace the CA3083 chips, and THAT chips, which might be the cause of this issue.
Anthony.
Also helps if I install C11....
Abe, in the parts kit you sent all the .33uF film capacitors as "185K", which implies 1.8uF. Is this ok to use?
Other than that, calibration is going smoothly.
Anthony.
hotel valkenburg said:got one of those 200 series VCAs off evilbay curious about the pin configuration, all the pins align correctly to the board, except there is no COMPR pin or that is to say it is cut short and soldered to the VCA's can. is this ok? or should i pop her free and hook it up? seems like it should be the ground pin thats connected to the can.
Baltazar said:Hello!
A few years after i ordered I finally had the time to start working on these rev2 boards!
First unit is assembled first i tried it without any ICs, no smoke, adjusted voltage to +15 and -15v.
With IC's in, +15 is fine but i cant get the negative side to go above -11,45v. R100 is out of range...
I also notice that the two LEDs illuminates a little all the time and the VU is pegging "downwards" so to say.
Remove one IC at the time until voltage bumps up or what is you suggestions?
Best
