I'd check my wiring on the pots. Also, move the PT around to see if that affects the hum. I was able to get pretty much zero hum by situating the torroid just right, though that may or may not help your specific problem.Spencerleehorton said:Getting hum on one unit no output apart from hum sound, going to replace TL082 IC's for TL072 or OPA2604.
Other unit passes audio to output, unit compresses but output gain when turned CW cuts out signal.
So need to get to the bottom of that?
Spence.
You can get the boards and cases through Dan Deurloo @ CollectiveCases.com. He's 100% reliable in my experience so you don't have to worry about the issues AC sound had.Deepdark said:Hi guys
Is anybody know what happened to AC sounds? I just came through their Facebook and things don't quiet looks god![]()
"The 160VU enhances the attack of snare and kick by expanding 15 to 20 milliseconds before the onset of compression..(as revealed to me by LesTyler its' designer)...as a product of its poor powersupply..which also can be seen in the slight dimming of the lamps on every beat "
