1. Calibrate RMS - insert -60db (whats -60db when measuring output with MM) 100hz sine wave on input, probe offset pin, adjust R36 until waveform is symmetrical.
2. RMS Symmetry - get right mark audioanalyzer software or distortion meter, set test tone to 100hz, start playback, adjust unit so its compressing 20db
adjust r34 until lowest distortion achieved.
3. Level Calibration - set tone to 100hz @ 1.228RMS (i set my MM to AC and adjust sine wave output to 1.228) set meter to input & turn R63 until voltage on end of R79 is -0.011 VDC.
4. Threshold Knob Adjustment - with 1.228VRMS on input turn threshold knob so both lights off, put knob on so it reads 1.2V
5. 1:4 Ratio Calibration - Adjust ratio to 4 and threshold CCW, input with -30db 100hz with no compression, adjust output for convenient reading on external VU meter (-30db) step up output of oscillator to +10db, output of clx-vu should be only 10db louder, adjust R43 until this is true.
6. Meter Calibration - confirm R109 disconnected, adjust R124 until meter reads 0, once done connect R109.
7. GR & Input Calibration - oscillator to 100hz @ 1.228VRMS, set threshold CW, Ratio CCW set meter to GR, adjust R51 until 0 on meter, Set meter to IN adjust R62 until 0 on meter, repeats until both set to 0.
8. Output Knob Adjustment - with 1.228VRMS on input set to output, adjust gain control so meter reads 0, attach output knob so it points to zero.
