Spencerleehorton
Ah ok, my version doesn’t work but it’s all round the wrong way as per the other pic. Will try reversing and hopefully will sort!!
BerndVP said:So, the IC I found now,
I see we need a 1.29M Ohm resistor, that doesn't exist off-coarse, so how did you guys fixed this ?
When it comes to component selection, you get familiar with the sound of certain components by doing comparisons. If you don't want to do that then I recommend going for parts with good specs (which tend to be more linear/transparent). I personally wouldn't see the point of going with orange drops here but maybe that sound works for you. Most of all, you're going to need to go with components that fit the PCB so the opportunity to experiment will be somewhat limited.BerndVP said:Ok! Thanks for the tip!
For all other components.
Has are their some tips?
I see people using some Orange Drops in some builds.
Bowie said:When it comes to component selection, you get familiar with the sound of certain components by doing comparisons. If you don't want to do that then I recommend going for parts with good specs (which tend to be more linear/transparent). I personally wouldn't see the point of going with orange drops here but maybe that sound works for you. Most of all, you're going to need to go with components that fit the PCB so the opportunity to experiment will be somewhat limited.
I looked up my Mouser BOM from over 6 years ago and most of the caps are no longer made. I won't share the resistors because I recall a lot of the Vishays I got were over-sized and did not fit so I don't want to recommend parts that don't fit. Here are some of the series types of caps I used;BerndVP said:@JMan, thanks!
@Bowie: are you willing to share you're components list so I can compare with mine ?
