No, not in white/blue. But, if you're willing to do the work you can just alter the colors on this one;znjamznjam said:Hallo
Have anybody good dbx vu scale from -40 till +20db.
In wite background with blue letters and numbers?
Something as in this picture
Please upload if you have. Thanks in advance.
znjamznjam said:I make this one. Same size for Hairball/Don Audio meter
BerndVP said:I'm totally stuck on this project, one of the board doesn't put output and with the working board I can't get the 4:1 ratio calibration.
Since the manual is not clear enough... I think it's a waste of a project...
AW said:Hi
I am going to build the CLX-VU, is there a mouser B.O.M for ordering the parts, aside from the PCB's, meters, and case. Is there also a place to order the push button switches?
Any information will help. I see from looking on this project discussion a lot of the links in the beginning of this discussion are broken.
Thanks, Tony
JMan said:The BOM can be found in the build guide. I’m not sure if anyone has a ready-to-go Mouser cart for this one. EDIT: looks like you’re in luck with the post below!
The push button switches can be ordered from Hairball Audio. I think Frank at frontpanels.de also has them, although I can’t remember if he stocks the one with the power switch as well.
BerndVP said:An did you got you're calibrated?
Because the PDF isn't really that good
