I believe we all agree that for 100% efficiency, a shield must be exempt of openings.Ok, so it seems there are two things going on here.
1) The video at 1:37 explains "Since the copper strips are all at the same potential, the net electric field inside the cylinder is always zero as we move the rod around". Meaning the even distribution of charge on the surface equates to a net field of zero within. If there was any kind of hole or slit or even a kink in the shield, it would not evenly distribute the charge and therefore changes in the external E field would be observable.
If is clear that the shield must be kept at a potential that is constant referenced to the audio circuit reference; in that case, there can't be variations of the electric field inside the shielded enclosure and wiring.2) Even if the shield is NOT kept at a constant potential, the net distribution of charge around the shield is still zero but these changes are still visible to the inner conductor.
I would even say that it's not necessarily a good solution in terms of noise. Having the mains earth and the audio earth separated means there could be longitudinal voltages between them. Pro audio gear should be relatively immune to that, but in almost every studio in the world there is an electric guitar...In the realms of recording studios, having the desk taken to a 'clean earth (dedicated thick cable and spike) while the multitrack uses mains earth is not 'optimal' when you have a thunderstorm.
Don't take this too seriously. These are good recommandations, but very short on explanation and don't differentiate the various causes of noise, conducted emissions in Line and Neutral conductors do not produce the same effects than conducted emissions in earth conductors, electrostatic fields are not differentiated from magnetic fields...and so on.
Just to make sure I understand: Safety grounds are the green wires coming from appliances and outlets going to the breaker panel, good?OK, so in a US type NEC (120/240V) AC power system:
a] the Safety Grounds are connected to the power company Neutral at the main breaker box.
the metal parts are bonded (attached) to the Safety Ground
the Safety Ground wire follows the Hot & Neutral wires (in close proximity) back to the main breaker box.
b] the Grounding Electrodes (ground rods, water pipe,or Ufer) connect to the power company Neutral at the main breaker box.
Are they? I don't think the electric company cares about hum in recording studios...So while there is continuity between the Safety Grounds and the Grounding Electrodes, their tasks or functions are different.
In some very old wiring the EGC (equipment grounding conductor) was bare wire, but yes green in typical modern 3-conductor insulated wiring. (Line or hot is typically black, and neutral return is white). But trust that color code at your own risk. My house is clearly not to modern code (2-conductor wiring).Just to make sure I understand: Safety grounds are the green wires coming from appliances and outlets going to the breaker panel, good?
What are the "metal parts" you mention?
UL certainly doesn't, their primary focus is human safety.Are they? I don't think the electric company cares about hum in recording studios...
Also metal outlet boxes, metal conduit (in North America at least typically only found in commercial construction, not residential housing, although may be in apartment style housing), and any metal building framing.Metal parts likely refers to plumbing (copper) in older homes.
Gas lines?Also
Yes, gas and water lines must also be connected to building ground.Gas lines?
I'd be curious to know the extent of that regulation. I know and understand that any mains-powered appliance or apparatus has to be earthed, but I fail to see the logic of earthing a patchbay for safety or regulatory reasons., because anything metal is connected to the building grounding conductor, if you have something like a patch bay in a commercial building, the exposed metal has to be connected to building ground.
