Hey, how is one to assemble this body with the microphone amp plus capsule attached? You cant slide it in like you would on other mics because of the reduction in inner diameter in the body tube. I want to have the whole thing assembled with capsule when i assemble and disassemble for easy servicing...now it seems a like a big pita if im not missing something here? Do I really need to unscrew the binder connector and the whole bottom piece, then pray that i can get it tight back on with the aluminum nut that keeps it secure? Theres like 5mm of clearance, so im not sure how to do this.
I really dont want to have to desolder the capsule anytime i need to get in to the mic. And I would certainly feel better not having to reduce the diameter of the top plate.
Please advice, im confused here ;D
edit: looking at skylars pics at ordering page, it seems that something is wierd, because it clearly shows a complete mic amp with capsule mounted with bottom plate, capsule, and internal rails. I cant get my mic inside the body tube when assembled the same way... Im one of the early beta testers, so is there something wrong with my body tube or top plate?
J
