I used a 175-0-175 trafo and replaced the rectifier tube with 2 diodes, as its half wave rectified the voltage should be around 248 volt but i measure 218 volt at CT of the output trafo.
the pot i used is a normal stereo pot 1/4w, resistors 1/2 W and C1 is 1uF. i used Solen Fast 630v for all the caps
