Dear TIIM, thanks a lot for the update.Hey Srdjan,
your transformer sounds fantastic !
Replaced it with my AMI T14.
The AMI T14 ist also excellent, but to my ears your transformers sounds slightly „better“.
I really appreciate your work !
Mine arrived yesterday, thanks guys!Great to hear that pacel was delivered in Canada!!! Thanks for letting me know.
It looks like there are only four non-delivered parcels (Italy, 2x Canada, USA). Guys pleas be patient!
Any cap types to avoid? I believe I read that wet tants fail to a short so I assume those would be a bad idea.Once more important note! Be sure that coupling caps in front of T14/1 are not leaky and be sure that you dont put any DC on primary side (blue blue leads). It means even measuring the resistance of the primary (it's around 3kohms) because primary side is winded with the ultra thin wire what will be burned in a milisecond if it meet even low DC curent (or voltage across primary). All the transformers are checked before the dispatch and tested for the desired inductance of the primary.
Cheers!
Akg used tantalum caps. They sound pretty nice but as you stated they fail to a short and than DC kills the T14/1. Also, paper in oil caps generally have a tendency to leak so that should be another type to avoid. Unfortunatelly both of the types sounds "interesting".Any cap types to avoid? I believe I read that wet tants fail to a short so I assume those would be a bad idea.
I have a couple Russian metalized paper caps lined up for this build. Any recommendation on how to test for DC leak? I have an LCR but it’s just a cheap one (DER EE DE-5000).
I will do my best to ASAP show you the progress of the Ü11, Ü35 & Ü54 transformers. Stay tunedAll Ü11 (C12a) preorders were moved here:
https://groupdiy.com/threads/feeler...-transformers-c12a-414eb-414ep-p48-etc.78668/
Pleas check the new preorder thread!!!
Nice! I ended up just using B+ and a resistor. Some of my MP caps were very leaky; decided just to use modern film caps.An LCR meter wouldnt be much good for testing caps for leakage , Its an AC signal it puts out .
Typically in tube amps a leaky cap will show a small dc voltage at the following grid , when you lift the cap from the grid/ resistor the leak voltage rises appreciably . A source of dc voltage appropriate to the cap your testing and a multimeter should be all you need , I have an old Heathkit RC bridge with cap leakage test , comes in usefull at times .
After this warning I wanted to know if there is some cap of the current production that "sound" close to one of my favorites, Rifa MP, to use with his T14 transformer. The Rifa now masure 1.33uf, the rest are very very close to 1uf.Once more important note! Be sure that coupling caps in front of T14/1 are not leaky and be sure that you dont put any DC on primary side (blue blue leads). It means even measuring the resistance of the primary (it's around 3kohms) because primary side is winded with the ultra thin wire what will be burned in a milisecond if it meet even low DC curent (or voltage across primary). All the transformers are checked before the dispatch and tested for the desired inductance of the primary.
Cheers!
The difference you heard was probably more the different capacitance than the different cap Type. I would, just to be sure try another but new 1.3uF cap and compare again .After this warning I wanted to know if there is some cap of the current production that "sound" close to one of my favorites, Rifa MP, to use with his T14 transformer. The Rifa now masure 1.33uf, the rest are very very close to 1uf.
The test mic is a MXL V77 without imput cap, Peluso CEK47, GE 6072 and Jensen DBE.
I have a 0.5uf (0.7) Koweg MP that sound very close to 1uf (1.33) Rifa, and some others MP of closer capacitance (1.2-1.4) and they sound different between each other. The MKPs are all strictly 1 uf and do sound different tooThe difference you heard was probably more the different capacitance than the different cap Type. I would, just to be sure try another but new 1.3uF cap and compare again .
