Echo North
mitsos said:hey mike, took a quick look but didn't see it on the site. Do you have mechanical drawings for the switches? I'd like to build a pushbutton comp and am getting a faceplate made, need to know where to drill/tap the mounting holes.
thanks!
The two mounting holes are centered on the top and bottom of the switch chassis. They are 3.2mm/0.126" in diameter (#4). They are 65mm/2.56" apart again centered on the cutout vertically and horizontally.
I use a 2.375" x 0.325" panel cutout.
Let me know if you need anything else, I can whip a sketch together.
Mike
