Luny Tune
Not much can be wrong, RegularJohn.
I'll ask you a couple of questions here:
Did you make the rectifier bridges for the meters yourself or were the meters already fitted with that internally? (The meter will not show VU reading without it so if you have a VU reading and didn't build the rectifier bridges yourself, they're already built in.)
Is the +8 reading correct?
(I suspect you've accidentally wired the 4k7 resistor on the meter switch so it's active on both the +4 and +8, but the 7-8 dB difference shakes that theory a bit, but you should check to see that the switch is wired correctly.)
What meters are you using. I can't make out a brand name on the pics. They look nice though.
