Perhaps someone will put iron to solder and put this to rest. I'm not suitably motivated at this time.
My motivation is not high either, simply too many more pressing projects and recordings to do. Nonetheless, I'll see if I can find some free minutes to spend on some breadboarding.
Aside from the general benefit of having a fully differential topology throughout, why did you choose to make this design completely balanced?
I'm not sure what you consider the "general benefit" of a fully balanced topology, so let me simply list a few thoughts on this:
* 6 dB more maximum output level
* very good rejection of ground noise and power supply ripple (at least if you run the output in a balanced input)
* potential cancellation of even-order harmonic distortion
* usually significant improvement on input CMRR (about 20 dB) compared to unbalanced loading of the input transformer
We should be aware of the disadvantages as well though:
* higher noise (with proper care excess noise can be low though)
* the output opamps see higher loading compared to an impedance balanced output (e.g. each opamp drives 300 ohm for a 600 ohm load), which might increase distortion a bit
* the input transformer might show higher distortion compared to unbalanced loading (according to personal communication with B. Whitlock)
Was this done to allow offset trimming at the frontend? I see the note about trimming R12 for -0.1 V offset, but this offset is still significant enough that we need output capacitors.
The problem with this offset is its driftyness (cool word, no? :green: )--it depends on transistor Vbe and beta, both pretty temperature dependent, so you can't simply trim it to zero and be done with it. I chose to trim this offset to -100 mV in order to polarise the output capacitors correctly at any temperature.
Also, would this design do well with lower turns ratio input transformer? As low as 1:2 or 1:3.5?
Basically yes. For best noise performance you'd need to change the collector current of the input transistors though. If you are interested and have a specific transformer in mind, let me know and I'll point you to the necessary changes.
Could design F work with OP275 in place of OPA2134? These have been cited as substitutes for one another.
The OP275 has very limited input common mode range, and that's of serious disadvantage here (it might not work at all here if simply dropped in). But again that could be changed by providing different resistors defining the collector currents.
Also, are there any details to pay particularly close attention to in building this design?
It's always cool to keep the input at a good distance from the output to avoid positive feedback at high gains. The power supply bypass capacitor should be located close to the opamp. In addition to this, I prefer to build things on a dual-layer PCB as this well keep routing thight and allow for ground planes.
BTW, I just checked the measurement data on the 2N4403 given in Motchenbacher, and they agree very well with the values I gave earlier in this thread.
Samuel
