DigitalMetal
- Joined
- Jul 10, 2009
- Messages
- 144
Ok guys after powering up my EQ modules, i decided to test the audio on them, and hooked up some temporary XLR's to the input and output moles headers on the EQ bus card.
I plugged up a tone generator to the input and an analyser on the output, set the generator to send 0db of 1khz tone.
The audio is not passing though the EQ whether i switch the EQ in or out,
with the tone switched off im getting -80db with it on im getting -60db so a tiny bit is bleeding through.
FYI i have pinned up as follows:
0V Pin 12c,14c,17c,18c
+18V Pin 16c
-18V Pin 19c,20c,22c
-25V Pin 21c
Master reset pint 1a tied to -24V through a 22KOhm resistor.
Out - Pin 29c
Out + Pin 30c
In - Pin 31c
In + Pin 32c
I didnt pin up the 6v i suspected i needed as it just says its for lamps on the pinout diagram.
Is there something obvious anywhere that ive missed out than somebody can see?
ive tried several of my 13 stereo and 4 mono EQ's and none of them are working so dont think they are all faulty.
Hopefully ive missed something really simple :'(
+18V Pin 16c
-25V Pin 21c
Out - Pin 29c
Out + Pin 30c
In - Pin 31c
In + Pin 32c
