Briomusic - did you ever get the meter problem sorted out?
piano said:briomusic said:Few problems left to deal with:
Meter in IN and OUT modes only shows signal applied to the right channel, but on both bargraphs. What could be causing this? (When calibrating I also noticed that only the right-hand Offset and Range trimmers had any effect on the LED meter.)
I have the same behavior. Signal applied to right channel, but on both bargraphs. Also I get the bargraph lighting up full but signal is overlayed that in a brighter LED. Cool effect but I am sure this is not what was intended.
The fix for this was not posted (well a diode was reversed - but that did not fix the problem.
What is the fix.
