Ben,
Hey. I built my MixBuzz using your BOM by the way. Very Helpful.
Is this correct?
Turbo off = detector listens to mono sum of input, Turbo on = Left and Right channels compress independently. So it's basically like the "Link" control on a stereo compressor?
Soft/Tight - Soft= attack and release controls are independent and work according to the values printed on the faceplate. Tight = automatic release, based on attack setting? OR, is this just a setting for soft knee or hard knee?
Dual = creates program dependent release timing
TL = "thrust loud." If this is like the API 2500, according to the Waves plug in manual, "a gradual linear filter attenuates level by 15dB at 20hz and increases level by 15dB at 20khz. This decreases low frequency pumping while increasing higher frequency compression."
TM = "thrust medium" = "a slight attenuation of the low frequencies and a slight boost of the high frequencies, with a flat mid range affecting the signal into the RMS detector. This reduces pumping caused by low frequencies and increases the RMS detectors’ sensitivity to higher frequencies, affecting higher frequency signal peaks."
Does this sound about right?
