crisotop said:So just stick two 10Ohm resistors between the rectifier on the psu board and the 12V regs on the main board and populate the couple of lytics for the 12V supply?
Christoph
electrochronic said:Would be great to see a project like this turned into a DIY black market offering any one could build with option for transformer coupled and transformerless as a option with a high quality signal path that rivals the big $$$ console boards (modular in design).
3) leave out the swap option of the insert order. This was very hard to do without logic switching and did add a lot of relays...
crisotop said:3) leave out the swap option of the insert order. This was very hard to do without logic switching and did add a lot of relays...
But this would be the key feature for me, besides a dedicated M/S Processing insert.
christoph
radiance said:electrochronic said:Would be great to see a project like this turned into a DIY black market offering
I thought about that....but my version turned out very specific. Everyone wants other options and to include them all would be too much of a design task.
However, if there's enough interest I will make an effort to redesign the pcb of my mixer, make it more simple. Along the way I've learned a couple of things that I probably would have done different when I had known them before.
For example,
1) I would leave out the dual mono vs. stereo option on the stereo input channels. This will lower the already very low bus noise since this option add's bus noise of another 20 channels where as stereo only has 10 channels per summing amp.
Instead make 2 mono channels or so...It also saves you 3 DOA,s and 30 relays and some other bits and pieces...
audiovisceral said:Ah but this would be such a key feature imo! The stereo/mono select is what makes these guys like the dangerous 2-bus and folcrum versatile. Plus 125dB noisefloor is fantastic enough already, by any standard.
audiovisceral said:If you ever get fabio/gustav/etc to do a pcb run and sell them I'd love to make one. The only change I'd make is to only have 1 (instead of 2) send groups/inserts. Bu I would be perfectly happy with it as is.
audiovisceral said:Amazing build. All those 990s must sound great! Are you happy with the sound vs. something like the dangerous unit?
Cheers.
radiance said:Sorry, I was not very clear on the reason to ditch the mono stereo option. The main reason is that it makes the build almost twice as complicated. Channels set to dual mono are summed by their own mono summing bus. That signal is split and routed to both left and right bus. True, it makes the unit very versatile, but in real live I only use two stereo channels in dual mono mode. I might design the pcb so you can choose which and how many channels will be mono or stereo. This will be done by means of hardwireing them instead of making it switchable. It will save you about 30 relays, 3 990 doa's, 9 604opa's and a lot of pcb real estate
audiovisceral said:Would it be possible to include the mono/stereo switching section on the pcb, but make it easily bypassable via jumpers or hardwire cables?
Bogart said:Very nice work!
I can see you've got a SSL style with your builds
I assume you used the (hard to find) EAO series 01 pushbuttons, where did you get them from? Did you replace the LED to get a different color?
radiance said:I've used 24V ones. They run on something like 19V though...not as bright but longer life..
"not as bright but longer life" sounds like an add for ECO friendly washing powder . . . .
Bogart said:do you think I could get 12V lamps and then just add a resistor in between?
Bogart said:Could I hook them up in parallel or should I find another solution? Cheers,
radiance said:Bogart said:do you think I could get 12V lamps and then just add a resistor in between?
Yes, add a resistor to drop the voltage to whatever you need (ohms law).
It might be a good idea to make a separate (off board) PSU with LM317 /337 regulators. This way there's less chance you'll get hum.
Sorry, don't get your question....
Bogart said:One last question (at least for now ), on the first and second clone you built, can you confirm you used single pole EAO switches?
sahib said:...... I still think that those components through the aluminium heatsink on the psu is not a good design practice without any insulation around them.
