Yes, that is right. If the heater is broken, then it is drawing no current and you will measure a high voltage at the dropping resistor - same voltage at both ends?Zottel said:But i thought that the dropping resistor is serially connected to the heater resistance. And because this thing is broken and has a infinit resistance all the voltage is measured at this point. (Hard to translate)
Is the mic fully assembled, head-grille and all, or is some of it open?Zottel said:Hey guys,
today i got a new tube from andreas. Checked everything and this is what happens when i turn on the mic:
https://dl.dropboxusercontent.com/u/56430716/humming.mp3
The Volt's at the tube measure right. Everything looks fine. :'(
