commanderberti
have anybody a picture from this dual capsule, any information about capsule voltage, uF value, schematic with values of the electronic components ?! thanks for any info
As desribed in another thread, the original 1993 C3000 had two capsules, a miniature electret omni and a large hypercardioid. Switching from hyper to cardioid activated the omni which nulled the rear lobe of the hyper to produce the cardioid pattern.
perfekt! thank you!I think i might have what would appear to be the schematic for the first C3000 - at least it contains a "kugel" ("ball", ie. omni electret) connection and a "hyperniere" (hypercardioid) connection.
so i think if voltage internal is 12v ... the hyperniere has 0,5v palarisation ?! (560k -27K)I think i might have what would appear to be the schematic for the first C3000 - at least it contains a "kugel" ("ball", ie. omni electret) connection and a "hyperniere" (hypercardioid) connection.
1st pic shows the three red rear switches, which distinguish this mic from the later (so-called) C3000s, and the old-style logo of three intersecting cardioid symbols. The 2nd pic shows the internals of two of the original C3000s, with the extra teeny top-most electret.
h TboJa, ich habe mehrere .. Ich werde ein oder zwei ausgraben. Es handelt sich nicht um die übliche "Doppelkapsel"-Anordnung Rücken an Rücken; Es ist ein winziges kreisförmiges Elektret über einem größeren Elektret.
Das 1. Bild zeigt die drei roten Schalter auf der Rückseite, die dieses Mikrofon von den späteren (sogenannten) C3000s unterscheiden, und das altmodische Logo von drei sich kreuzenden Nierensymbolen. Das 2. Bild zeigt das Innenleben von zwei der originalen C3000, mit dem extra klitzekleinen obersten Elektret.
are both capsules Elektret ?Yes I have several ..I'll dig out one or two. It's not the usual 'dual capsule' back-to-back arrangement; it's a tiny circular electret above a larger electret.
Both seem to be the same photo?
Yes, both capsules are electret: 9v-52v phantom required.h Tbo
Are you sure?Yes, both capsules are electret: 9v-52v phantom required.
Are you sure?
The schem in post #6 seems to show polarization voltage applied to the hyper capsule via a 3.3 gig resistor.
It needs phantom for the electronics to work; doesn't mean the large capsule is an electret.Yes, I'm absolutely sure, as I've run these off AKG's own (old) 9v PP3 battery inline power supply (I have six of these (6x AKG C3000) and the specs in the 1997 AKG catalogue says, and I quote.. "POWER REQUIREMENT: 9·52V phantom power to DIN 45596".
See attached..
The schem was already provided in post #6.I have uploaded the service manuals for the C3000, C3000B and the C4000 here:
https://groupdiy.com/threads/akg.44737/
These include schematics.
