Hi Igor,
Yeah I understand - serves me right for not checking before labelling my front panel anyway
I have one question (read problem
All my source and speaker selectors work correctly, the volume knob works correctly and mono button works correctly.
However, when I press dim, it selects source 2, and when I press trim it also changes the source (presumably to 4 cos I hear the relays click, but that button is not hooked up on my monitor controller).
I have looked at the schematic, and I see that input 2 and dim are connected, and also input 4 and trim are connected too. I have gone round with a multimeter making sure there are no shorts based on what should be connected in the schematic, but I can't find anything that seems wrong.
Do you have any idea what could cause the dim button to select input 2? I'm sure this must be a wiring issue, but do you have any idea where to look based on my explanation as I am stuck?
Bear in mind that I have wired all my controls off board so there
is the potential for short circuits etc, but this did all work properly before I put it in the case, so I'm worried now that I may have damaged the CRM chip. Could this be possible?
Rob
