Hi Ruairi, yap, I know about delivery
10% off from CRM kit's price for your patience
1) How is the mono function handled - is it purely passive? I've seen people raise concerns about passive mono summing solutions before due to the source outputs having to drive a near short when the attenuation is set to a certain level. Any thoughts?
Attenuator's impedance kept very low (3kOhm), it is the point op-amps at soundcard outs are still clean but attenuator's output impedance
worst case is about 800 Ohms, enough to drive long non-audiofool (2-5m cable) without sacrificing transient responce.
Mono function is passive sum through resistors, before attenuator, btw, you can add +6dB offset (user-define-able) for mono.
2) I'm not sure how the talkback combiner is implemented? Is it possible to use the combiner board and set it up so that the TB signal only just goes straight to a dedicated set of outputs - in my case I could use the sub outs or add another set?
It is simple pair of line-receivers, resistors/opto network which combines source with electeret mic signal and take
level of playback 7 db down when TB pressed, followed by buffer...
In other words, make playback mix for performer on outs 3-4 of workstation; feed it into talkback combiner,
connect talkback combiner's out to phone amp, that's all.
Talkback combiner can be supplied from digital (12v) power supply, I used for this purpose $10 1W DC-DC converter (12->+/-15V).
In this case, TB combiner's ground fully separeted from digital ground.
