NOON
There's free and/ or open source PDF readers that you can do a Save As from and change some of the settings like image compression etc to reduce file size.
You can send it to me PM via https://wetransfer.com/ and i will reduce it. I have Acrobat Pro. P.Question for the group: does anyone know how to reduce the size of a PDF without Acrobat? And what is the actual file size limit for the forum? I have the build guide ready to go, but it is too large to upload thanks to all of the pictures.
While waiting for the first post to be updated again, here you goWhat happened to the BOM. was about to make the cart and buy the order.
I have no trouble seeing the schematic in the build guide, nor the actual separate pdf in the first postGreetings ! Thank you for this posting .
I am seeing the BOM but not the actual Schematic.
I am wondering if anyone else is having this oddity ?
Did your metalwork come from Frank or from Kevin? The countersunk hole(s) for the bolts that hold the output transformer are drilled for M2 and the others are M3.How do I put it together? Some pics from bottom plate...i ask beacouse on my eye, chamfer holes are to big...
