Good stuff! Yeah I’ll get some dimensions for the faders in question in a week or two. I wish I knew how to actually do 3D CAD stuff…Give me the precise fader cap dimensions and I’ll do that, it’s quite easily done
For starters I wanted to do something true to the original. A rectangular piece of brass can be bent into a circular insert, drilled and tapped. Or maybe the original can be found ?
For my personal use I was thinking of having the screw hole drilled at 2.5mm and then tapped for m3 set screw + inside central hole at the correct size for the pot shaft. Milled in aluminium
Edit: here are some pictures taken from two different Reverb sales
I did something SUPER simple in Autodesk Tinkercad once, but that's obviously pretty limited. Will look into Sketchup!I’ll be happy to do it for you
(I am using Fusion 360, but Google Sketchup is pretty easy to use)
