In fact I'm asking help from everybody in the forum, the mic was a bit noisy (some amount of white noise not proper for acoustic guitars but ok for drums), I changed the 3,2µ and the cermamic heater supply decoupling cap , it didn't change anything.
Then I tried to change the 180M resistor polarizing the capsule from HV with a 150M and a 30M in series, and I checked every solder with a lot of care, then it was worse, so I put back the original 180M resistor, and and was still bad : ocean noise, sometimes dissapearing and getting quite ok (even better than than in the beginning.. or it's just my imagination) sometimes coming back really bad...
Did I somehow traumatised the tube, or is there some other things to try to fix the problem?
