kante1603
gandhalf3 said:gandhalf3 said:Hello, I'v finished my Sontec, and he is not working well. I v'got two problemes :
1. When I turn the Gain on a band clockwise, the level of the band is decreasing, and when i turn counter clockwise is increasing. (Same probleme on each band)
2. I'v Got MF3 on each channel don't working. strange. (In fact when I Turn the knob full CCW I'v got a boost of all the spectrum about 0,5db and CW a -0,5db on all the spectrum.)
I need your help.
Thanks 8)
Please help ! :'(
Hello gandhalf,
seems that all of your gainpots are reversed meaning you have the in and out of each pot swapped (the both outer pins).
This can only be achieved if you have mounted them off board (swapped the outer wires-easy fix!) or mounted them on the wrong side of the pcb!
It would be helpfull if you can show us a picture of your pot-mounting.
For your MF3-issue (do you mean the third band from the left?) I can not help at the moment,but this is a differnt thing-maybe we can see more when we have the pics.
Hope to have helped,
Udo.
