bruno2000
OK, DO NOT PUT THE RELAY ON THE "SOLDER" SIDE OF THE BOARD!~
This does nothing but make your project look bad. Cut 2 traces, install 2 jumpers.
As the poster said above, just look at the schematic. The solution to permanent HPF bypass is pretty obvious.
Bruno2000
Bruno2000
atticmike said:bruno, could you tell me which RL it is (I suppose RL2?) and roughly trace the shorted-out section on a picture to deactivate the HPF.
Also another thing. I've really tried to get my head around the polarity issue of RL3 and your reference that simply swapping the two sides of the relay (under the board positioning) and yet not yielding a flip leads me to think that the issue has nothing to do with swapping both sides but rather with the misallocation of those two pins on the board and redirecting them ?
Could I also just place it the way it was (falsely), and simply swap hot and cold?
That's the way I mounted it of course without the red and black cables:
Mike
