- Joined
- Jul 15, 2009
- Messages
- 2,310
lauritz said:granger.frederic said:Dear Lauritz/PhatplanetStudio,
congratulations you have a near perfect Elam 251 plot : see the original plots at http://recordinghacks.com/pdf/telefunken/ElaM-250-251-Manual.pdf ,
you're near the specs...
but if u want to be sure , double check B+ with the mic plugged : max 110V , check the heater : 6.3V , check that all the HiZ sections are perfectly cleaned , check the capsule voltage before the 8Mohms resistors : around 60V
If your capsule is a bit low end shy for your taste, try to decrease capsule voltage to 55V (reduce the 0.5MOhms to ground), increase the 30Mohms grid resistor to 300Mohms and put a 100uF on the cathode instead of 22uF. U could increase the output coupling capacitor up to 3.3uF as well ....
with the high end response, assuming your plot is accurate , i would increase the output LP filter by increasing the 120pF to 220pF or even 330pF ... (or more to taste)
regards
Fred
Thanks a lot for your thoughts on the matter...i see now from the schematic that there is a 100k resistor on the way to the anode. With approx. 0,5mA current it leads to a 50V voltage drop, so i guess 160V is more than low enough -measuring directly at the output of the power supply.
Another quick question...i am saving up money for a Tim Cambell capsule, so i don't have a capsule yet. Would there be any problems just putting in 2 capacitors with electrical equivalent values( as the capsule ) and do circuit checks like that? Do i even need that, or could i just power up the mic without the capsule installed?
thanks
best
Lauritz
Not Really , you need the output from the psu when the mic is connected and loaded to be 110V,
you cannot account for this with the plate resistor , cause everything parameter on the bias and plate will be off
the best way to do this is to emulate a dummmy load with calculating the resistor required to test it under load wihout the need of the mic both for heaters and B+ , this way you dont over blow the tube , if you have a little higher voltage you can increase a little more R1 and R2
Dan,
