- Joined
- Jul 15, 2009
- Messages
- 2,310
Ok , here is some tweaks you can do from original schemtics,
Tweak #1
If your capsule is a bit low end shy for your taste, try to decrease capsule voltage to 55V (reduce the 0.5MOhms to ground), increase the 30Mohms grid resistor to 300Mohms and put a 100uF on the cathode instead of 22uF. U could increase the output coupling capacitor up to 3.3uF as well ....
with the high end response, assuming your plot is accurate , i would increase the output LP filter by increasing the 120pF to 220pF or even 330pF ... (or more to taste)
Tweak #2
1. Grid to ground resistor higher 100m or 250m
2. Increase or decrease output coupling cap to taste to modify low end response
Tweak #3
Hi there, I actually did buy the resistors but not yet installed them, in the meantime though I did switch the .22 uf Tantalum to a 100uf Tantalum and did not hear a change. Then later switched the 100uf Tantalum to a 100uf gold panasonic electrolytic and man the bottom really came up then. I did not have much time to test it on acoustic guitar yet, but the low on my vocal was much more without being muddy or too much. I will try the resistor change to lower the voltage down to 55V soon, I was sort of wanting to see if what I had calculated was correct first. I guess it won't damage anything to try! I will keep you posted as I proceed!
Thanks again
Tweak #1
Tweak #2
Tweak #3
Thanks again
