Tim Campbell
It could be a short between the backplates or you've wired the capsule incorrectly.
Banzai said:The AMI T14 also doesn't roll off the highs like an original T14/1. It has a noticeably brighter response.
Bonnie1 said:That's correct the AMI T14 Hi roll off is not at the same freq. as the Haufe T14/1. it's extended a wee bit.
Nusoundz description "8-12k is overly present" does not sound like the result of a component with a slight freq. extension.
It is possible AMI T14 is contributing 1-1.5 db, however not the fundamental cause.
micaddict said:Not to hijack, (well, not for long anyway), but what about the T67 versus Neumann's BV12 in this regard?
NuSoundz said:I have indeed ordered a GE 5 Star tube to see if I get the desired result or a more favorable one. I'm sure it could be a couple different things going on. I'm not blaming any particular component at this time as it's to early to point out the exact cause. I appreciate the feedback and will update once I have received the tube and perhaps post some clips with each tube.
NuSoundz said:Absolutely. I'm not expecting an exact replica of the real thing but a loose relative is fine. However, if the mic is unusuable in many applications (requiring too much eqing etc.) then I have a problem with that.
Regarding the resistor, what would you suggest as a "not so bright alternative". I'm new to this so please excuse the ignorance on my part.
