Hey I just loved your sample! So much, where can I buy the whole song? I looked online but couldn't find it. Fab production, singing, playing. Great song! Thx!kcguitar said:Ok, here we go folks with the C12/ELAM shootout. My CT12 equipped Chunger C12 vs CT12 equipped poctop ELAM. Both mics were run into a vintage 1099 (1073 with fixed line gain) with no EQ or compression and straight to my SSL madi converters. First is the C12, second is the ELAM. I purposely mixed the backing track low fyi. Results were what I expected...
https://soundcloud.com/paradyne-studios/i-love-you-c12-then-elam-mic
HarmonyUnited said:Also, I've seen mixed information of weather to set B+ to 110v or 120v... is there a definitive consensus on this?
stribor1 said:The Link to the schematics on the first page is not working anymore. Can someone please repost the docs?
J.
HarmonyUnited said:If you want ANY of the broken links just go to:
https://archive.org/web/
Copy the link from the first page of the forum and paste the URL into the wayback machine and click the date link. I used this to look at some of the photos aswell as all the document files.
Cheers!
HarmonyUnited said:Hey J,
I had the same problem and used the wayback machine to look for the images with success...
Here are two of the D-Elam251 schematics....
https://web.archive.org/web/20160915002210/https://dl.dropboxusercontent.com/u/43869772/Elam%20251/Elam%20251/Elam%20251%20Pictorial/Schemtic%20D-E251E.pdf
https://web.archive.org/web/20160915024854/https://cdn.groupbuilder.com/groupdiy/u/39511/58d1402a06461.pdf
Cheers!
HarmonyUnited said:I have a noise tested 6072a but swapped it out for other tubes with no change in the white noise.
Delta Sigma said:Tube socket? Check that your pins are seating correctly - see if any of the mating pins in the socket are damaged or pushed to one side.
You could always replace the styroflex with any type of cap. Even a different but similar value. It might not sound good but it'll help in troubleshooting.
Don't rule out grounding.
What about your audio pair inside the power supply? Twisted? Short? Avoids filter caps?
Gus said:How are the tubes noise tested? In a microphone circuit or in a lower input resistance audio circuit? This matters a lot.
What tubes NOS or modern built brands are you using and how many have you tried? Tubes can have noise issues with tube microphone circuits
And here are the photos of the circuit parts...Delta Sigma said:Did you "bypass" the capsule on the capsule side of the relays or the amp side?
Could be relay wiring. Does the same noise exist in all patterns? White noise louder or quieter in cardiod? Your signal will be louder in cardiod so generally your noise is quieter in cardiod.
HarmonyUnited said:And here are the photos of the circuit parts...
I bypassed the capsule at the capsule... just put 100pf caps in place of the capsule sides. Not sure how I can bypass the capsule at the amp side. The Noise is pretty much the same in all patterns with the capsule wired in. When i wired the capacitors in place though the noise was quieter in figure 8. which was weird...
Thanks again y'all!!
-Eric
