bcarso
"What about a 12v one? 12v rectified would be 16.8. Wouldn´t this be enought for the regulator? A 12.6 volt one is hard to find for me. "
It used to be the other way around, when 12.6VAC was the readily available trafo, but I guess times have finally changed.
Don't forget diode voltage drops in your estimation.
Yes 12.0VAC would be fine. To see what the reg will see put a load equal to the total filament current across the supply and look at the minimum points of the ripple riding on the d.c. when rectifying 17.0V peak. It might be good to use "real" diodes of the type you intend to use rather than Circuitmaker's default bridge, and you could put a little R in series with the trafo secondary for winding resistance (this is taken into account for a.c. loads by the trafo vendor---in fact a better model takes the real open-circuit voltage of the trafo and then adds resistance).
The regulator is happy with about 2V or more across it.
Note as well that the tolerance of the output voltage for some versions of the 7812 is rather poor, so you can have an output V for some ranging from 11.4 to 12.6 taking all the variables into account.
(BTW also somewhat related: see the latest AudioXpress for a controversial article on tube heater operation)
