ptron said:
Igor said:
Cool! Arrived within a month, right?
well to be completely honest man.. israeli post i think is top notch. it arrived into mexico (sealed on the box) by 10 days... hehe then here it lagged for another 4 weeks give or take.
thanks a lot tho
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
all is great here i still havent been able to check all the components but i reckn its all there.
so nice and tidy ! i dont want to open the bags yet untill i get a day or two to do it properly.
i sent email to cinemag but they havent come back with anything yet.. been about a month ... i really almost throwing the towel with that now.
all the best!
Regarding the shipping: you had some luck
About 88% of packages are arriving within 2-3 weeks.
About 10% of packages arriving within a month+. Really, don't know what possible to do with this.
Cinemags are not the only trannies on a planet, you can source Beclairs (TF10015/16) or Carnhills.
EA10468 and EA1066 are good too, I used them several times for 2254C.
ptron said:
hey yall! im just starting to separate the components from the kit and label them.. lot of work but wow can see igor put a lot of effort doing these kits .. thanks a lot for that!! anyways, i see there is nothing like IC sockets which is ok but something to do the matching with the diodes. i think i read on this thread igor or someone is using some milimax standoffs or something? i would love to know how i can search for them on mouser (by what name?) or if anyone has the part number i`d be greatful!
thanks a lot
8x 1N4153 are already matched, they are located in separate bag. Resistors for control and main PCB are located in separate bags too, more or less in logic order.
IC sockets: don't need them. Solder diodes and TL072 directly. I pulled sockets for diodes from regular 14 pin IC socket in first 2254C's; not necessary IMO,
why have I change them if diodes are already matched???
Price - wise: as long as I building 2254C for my customers from time to time, have to hold stock of components.
This way, I prefer to sell kits for reasonable price and buy parts in significant qty's to reduce my own investment in inits I build.
For example, sourcing same components for one compressor from 2 suppliers will cost you bit more than kit.
In other words, everybody are happy.
pacemaker said:
ok problem solved, those sh**** trimpots were blocked in 5k,
don't know why, but i changed them for Bourns ones and now it works like a charm,
so let's finished calibration for this gem !!
thanks again Igor for such a great projetc !!
regards,
Francois
Dat's great! Very happy to hear about this.
Francois: pls let me know if received the last package. (shipping, again!!! Talk to me on skype).
ptron said:
hey! just an update.. i almost finished separating and locating everything. its all there!(almost). just a couple of things im not 100% sure ill post tomorow with pictures if possible.
from the top of my head.. i think the tantalums i wasnt sure (there were 4x10uF inside a lil baggy all on their own.. also a few 10uF electrolythic that i think should be axial are radial.
i got a couple of questions tho..
does anything have to be grounded with standoffs? do i have to get metal standoffs? (i was going to anyways but.. the next question)
does anyone know about those separators that go like standoffs but between the pcbs? how can i look for those too?
also was going to ask if 1N4004 could be replaced with 1n4007 but i think looking at the BOM from the power supply the answer is yes?
from looking at bom from power supply also, then if i instal R5 to make it 24V, i dont need the NI trimmer?
im excited about this project ! going to have a read thru again just to make sure i dont miss anything before i get to put all together.
thanks a lot!
10uF blue electrolitics, Philips audio grade, yep, radial ones.
Standoffs: I use metal standoffs with plastic isolators or plastic standoffs for main board.
Main board shouldn't be grounded at standoffs. I used ground schem from the power supply starground.
BTW, you see on power supply two pads, G4 at top, nonamed at bottom, and hole marked G2. Connect them together; install power supply on metal standoffs,
for me it worked like a charm with all 2254C's, all quiet as Addams cemetery.
r5=3k57, NotInstall the trimmer.
1n4004 or 4007, no matter (should be general purpose diode, 1A)
Cool than... Please satisfy my curiosity and show working unit's pictures!
