dmnieto
mics said:Thanks for the kind review of the ck12. We do put many hours into these, we love them! They're worth the effort as you are right, they sound so great.
I look forward receiving mine... *salivating*
dmnieto said:mics said:Thanks for the kind review of the ck12. We do put many hours into these, we love them! They're worth the effort as you are right, they sound so great.
rob61 said:First time replacing a capsule, so a few questions. I ordered the K8 because it has isolated backplates per the description. My vintage U-87 has isolated backplates with 4 wires (very thick insulation between the two backplates). The K8 has 3 wires, and if I use a continuity tester I have conductance between the two backplates. So does the K8 work in the original 4 wire U-87 with full pattern selection? Also if the blackplates are insulated, should there be conductance between them?
duantro said:Are you reading my mind?! Will you post when they are completed?
Your capsule has shipped!duantro said:Are you reading my mind?! Will you post when they are completed?
