dmnieto
Can I get two myself?
(Shipment can be either to Spain or California)
RuudNL said:Here is the solution: ;D
dmnieto said:Ruud, I am just examining the bodies now.
On the plate that is used to hold the capsule, it seems that i would need to drill the holes myself to fit the cradle and the cables, correct? Unless I am missing something on the construction of course.
RuudNL said:Yes, it is as easy as that!
The insert is glued inside the Neutriks.
Unscrew them, put them (with the pins down) on the table at hit the back of the insert with a heavy object.
The glue will break and now you can take out the original insert.
Put in the new 7 pin insert et volià!
RuudNL said:Conductive glue, as used to repair PCB'sHow does one make the connection between mesh and body
how thick is the bottom part
