david-p said:Got mine. Thanks! A really nice job!
I have some (probably dumb) questions:
Body:
1. Although the struts are vertical, I am having difficulty lining up the two side screws that go into them to hold the head basket onto the body. Any hints?
2. Am I right in thinking that the perspex spacer is not needed for the Equinox capsule?
3. I am wondering why the screws with the allen key are used to attach this spacer. What would have been wrong with regular screws? This method, with a thread cut into both the plastic and the metal makes it difficult, if not impossible, to avoid a gap between the plastic and the metal. I would be pleased to be corrected if I am doing this wrong.
Capsules: Mine came with two little screws and six washers.
1. How are the washers intended to be used?
2. What is the purpose of the third hole on the capsule?
3. If for for pressure equalization, why is it tapped?
Thanks, again!
David
techix said:> Capsules: Mine came with two little screws and six washers.
The 3rd hole on the capsule is for your ground wire; see the capsule manual.
techix said:Try inserting and the set screw into the spacer first, and once the tip starts to emerge from the other side, screw into the capsule plate.
Soeren_DK said:Is it still possibly to order the capsule?
Will it work for the G7 project?
Soren
Le Roux said:I plan on using a G7 with a Dale M7 capsule in the EQU47 mic body. Would you recommend this mod for the Dale M7 capsule also?
And what exactly do you mean by back plate sticking?
Neil
Body:
Thanks, again!
David
david-p said:I am trying to figure out what cable to buy. There appear to be two excellent ones, designed specially for tube amplifiers:
1. Gotham 20101 GAC-7 has 7 conductors and good shielding, and an outer diameter of 6.2 mm
2. Mogami make W3172 Tube Mic Cable which has three pairs of different wire diameter, for heater, HT, and audio (twisted pair). Outer diameter is 6.5 mm
Both of these cost around $2 per foot.
3. There is also Mogami W2642 which has 7 26AWG conductors and is 5.0 mm outer diameter. Price is c. $1.05 per foot.
Does anybody have experience of any of these cables?
Would there be insoluble problems in trying to get 6.5 mm cable through the hole provided by the Binder connector?
David
