damianschwartz
I´m in also for the second batch, can´t wait for it!!!!
jsteiger said:FWIW, the boys and I are currently contemplating a 200pc run. That should be enough to satsify most of the needs out there right now.![]()
zayance said:
OK guys, we have it in writing!Ptownkid said:I'm certainly up for another. I can 100% guarantee that even at 200 pieces, you will sell out, period.
Yes, most 500 series modules will work fine. Some may need some adjustment.frederikkofoed said:This might be a stupid question, but will it be possible to use regular 500 Series modules with this case??.
Btw. whats the price going to be??
- Frederik
jsteiger said:Yes, most 500 series modules will work fine. Some may need some adjustment.frederikkofoed said:This might be a stupid question, but will it be possible to use regular 500 Series modules with this case??.
- Frederik
Here's the skinny.
You can easily build the rack with all 15 pin card edge connectors. PSU will cost you less money to build or you can even buy a ready made unit from Power One, BAE and so on.
If you go with all 18 pin card edge connectors, some of the 500 series modules that have a full metal enclosure around the back (Like most API eq's) will have to be slightly modified/notched on the back or the metal enclosure can be removed. The bottom of those metal enclosures hit the longer 18 pin card edge connector.
The down fall to only 15 pin edge connectors is you loose the benefit of the extra higher voltage rails. I think we are gonna be seeing a lot of new modules that will be running on the +/-24V rails in the future.
Cheers, Jeff
