GssL 20th Anniversary edition
I wanted to ask , would I need to use an extra pcb like expat's VU meter pcb in order to use a SIFAM R22 Vu meter? I got a vintage one that I've been dying to use for a project!
Errors in the BOM for "Release": It's not 2 x 1M2, just one. But two 2 x 750K instead of 1
Error in the BOM for "Ratio":4 x 3M9 not 6x. Also maybe 2 x 3M3 (which are not in BOM)
Error in the BOM for "Side Chain HPF": missing 2 x 1nf (but in orderlist from reichelt)
Unclear: Label ATT = 0,0R ? If yes, only 1 x 0,0R in Sidechain
Error in Reichelt Part Order:
2x1M4 in Ratio missing
I caught your first edit and added the correction after, but if you keep editing this one post and adding to it, we cant be sure I can keep track, so better gather a few things and post.
Added 2 x 1nF in BOM for SC
Reichelt doesnt have 1M4 resistors, but I can see I doubled up on 750K to put in series instead in the cart.
Already see 2 x 0R in the sidechain BOM, but added 1 x 0R to the attack portion of BOM.
ATT is just jumpers going to the Attack. We do a hard bypass on this unit, but I marked this spot with the ATT resistor going to attack, because thats where we cut the signal in soft bypass on the original project, and some expressed a want to maybe do their build with both options.
Gustav
@Gustav Excuse me if it's a silly question but do the 2 gain terminals connect together at a single pot ? You've mentioned that for the gain we need 1 x 10k lin ( not a stereo pot ? )
Also , I've seen that in your prototype you've chained together the XLR grounds as I can see in the original build guide as well , I assume this is not necessary if I mount the XLR directly on the pcb?
Thank you!
Question in the "Color" Section:
i do see 2 x TRM , is that TERMination or TRIM ?
and the 22uf is that 22u/35V ?
And is that 10uf mks in SC_HPF ? or is that 10 uf bipolar ?
Thank you!
These are simply mislabeled, because I copy pasted the part from the gain and forgot to rename.
If you look at the actual connections, these are alternatives to PCB mount XLR, so you wire via a connector.
Ill add it to the errata list.
Gustav
Error in Reichelt Order List:
1206 Input, 4 x 100R in BOM, in Order List only 2
Error in BOM - Blend
Its 16x10K in Total (also Order List wrong)
Side Chain: 2x10K missing in Bom+Orderlist
Error in BOM + Orderlist
Release has only 1 x 1M2 not 2
Ratio has 4 x 3M9 not 6 x 3M9
Error inn Orderlist somewhere, Not 2 x 2k2 just 1 x 1k1
Unsure of the wordings here, like "Not 2 x 2K2, just 1 x 1K1" Too many 2K2, 2 x 2K2 missing? And also unsure if you are adding things that were already corrected (4 x 3M9, not 6 x 3M9) adn "only 1x 1M2 not 2 (so we need 2, or there is 2 and we need only 1?)
- also, I think it would be more helpfull if you would gather up a bit of these, so you have at least a days interval, just to make sure some things dont get lost in the stream. It gets a little overflown if we use this format in a chatroom manner.
Ill ignore the last two posts, and you can gather up what you have in one in maybe a days time!?
Gustav
Gustav
Okay, i clarified it here:
Section "1206 Input"
4 x 100R in BOM correct, but Only 2 pcs referenced in Order List (Warenkorb)
Section "BLEND"
Number of 10k is incorrect. Actually those are 16pcs. Error in BOM+Order List
Section "SIDE CHAIN"
2x10K not in BOM and not in Orderlist.
Section "RELEASE"
Only 1 x 1M2 not 2x1M2 ; Error in BOM & Orderlist
Section "Ratio"
Only 4 x 3M9 not 6 x 3M9 ; Error in BOM & Orderlist
Section "Side Chain Sum"
BOM states 1x2k2 ; in Orderlist it is 2x2,20K
Hope that clears up confusion
Corrected from 2 to 4 pcs 100R in Reichelt cart
Section "BLEND"
Corrected from 10 pcs to 16 pcs 10K in BOM
Corrected from 10 pcs to 16 pcs 10K in Reichelt Cart
Corrected from 0 x 10K to 2 x 10K to BOM
Corrected from 0 x 10K to 2 x 10K to Reichelt Cart
Section "RELEASE"
Section "Ratio"
Are you sure these are not the ones I verified correcting earlier?
https://groupdiy.com/threads/gssl-20th-anniversary-edition.88092/page-12#post-1184501
Or do you want me to change 4 x 3M9 to 6 pcs, and 1 x 1M2 to 2 pcs?
How many is correct?
Okay. for the
Section "RELEASE"
Only 1 x 1M2 used on PCB not 2x1M2 as errornous indicated in BOM & Orderlist
Section "Ratio"
Only 4 x 3M9 used on PCB not 6 x 3M9 as errornous inaidicated in BOM & Orderlist
Only 1 x 2k2 are used, BOM is correct, only Orderlist is wrong with 2 x 2,20k
Section "RELEASE"
Section "Ratio"
These are correct.
Changed 2 x 2K2 to 1 x 2K2 in side chain sum cart at Reichelt.
I had shipping issues with packages @JMan , @oldskool1 and @Script. Packages came back and i need to re-ship them and lower package height (damn DHL - those are original packages). So i need 3 x 22,49 EUR payments again. Sorry for that. It's DHLs fault.
To outline, package is 1cm to large (no kidding) on right side, so they returned it to me :-( I re-cut the box to size of left side to get more than 1cm. The packaging material is exactly 45x35x10 and correctly measured. Really a BIG bummer today.
I'm certainly going in for one of these boards once all the errata is collected, fixed, etc. Really cool to see people already populating boards. I'm glad I screamed and yelled for this (new version GSSL) for a few months.....and someone listened! :) Great work.
