GssL 20th Anniversary edition
Don't be confused. I'll explain:
- BOMs and Reichelt Part Lists should be updated by now.
- the referenced Corrections "Rev 3 needs following..." need to be applied. It's in the blend Circuit as outlined, and the wrong part is in Side chain HP switch.
Let me know if i can assist you..
I'm still a bit confused about the errata
The errate under this header is not relevant to the rev 3 board.
Errata to make the test run board perfect
Its just left there to the handful of people who are building the test board...
...and none of it will make a difference between a unit just blowing up or not. If it did, it wouldve been posted in bold and repeated 20 times.
Gustav
@Gustav Are you aware of any other switches that could directly work on the switch pcbs? I was thinking of maybe using some grayhills and wire them.
There is something about the feel of the lorlins that I really don't enjoy
Sorry, I dont know of a switch that shares the exact footprint.
I also happen to think the Lorlins are great for most applications - including this one :) Of course, you can wire up anything you like, how you like, which is the great thing about DIY.
Gustav
Speaking of Wiring:
As i am using NRG illuminated Push Switch (like SSL Solid State Logic) - i found need 560 Ohm for the LED switch. There is no dedicated LED Resistor (or connector) somewhere on the PCB, correct ? Guess i can wire it to Pos12V and Resistor on the PCB.
Is there a definitive wiring guide ? As i see the pads like "Bypass in" (just as an example) and the associated X101-4 ( i assume )
If not i can try to start with one and get corrected when i am wrong ?!?
I started here:
Excel (2nd Sheet for Wiring) - please do see it as a discussion point - NOTHING VERIFIED yet - Out of that i will provide wiring diagram
Excel ist editable if you want to fix things.
Speaking of Wiring:
I started here:
That would be extremely helpful ! I've been reading a lot through the various threads and guides out there and I'm trying to figure it out myself as well
Speaking of Wiring:
I started here:
See attached for example of the connector relative to relays.
pin 1 carries 12V
pin 2 goes to relay switching
pin 3 bridges return voltage to relay switching over a drop resistor (handy for an LED)
pin 4 is connector to GND (also handy for an LED)
So in essense, you wire the switch so contact is made between 1 and 2 when you want to activate the relay
If you wire pin 3 to + and 4 to GND on a LED on your switch, if will light up when you make contact between pin 1 and 2.
You can also use this set-up for a toggle, wiring 1-2 to the toggle, 3-4 to the separate LED, or you can omit the LED and just use pin 1 and 2 to make the contact on a switch.
Varying the resistance within reasonable amounts will vary the LED intensity. 560 ohm seems awefully low. I would try with the 3K in place first, then adjust to taste.
Gustav
    13.2 KB
