GSSL - Doubt about IC sockets and molex conector
ctechdx
Brazil
Hello my friends,
I gonna build my first DIY project, the GSSL. I´m doing the cart on mouser, I found everything, but I´m in doubt about the ICs sockets and the molex conectors. There are so many opitions and the pictures usually doesn´t correspond to the piece. I don´t want to buy wrong pieces. I hope someone can help me with this.
I need the sockets for those iCs:
NE5532P
NE5534P
TL072IP
TL074CN
THAT2180B
And also the molex conector and cables:
5POLE. PIN connectors, PCB, 1/10" (2.54mm pitch)
10POLE. PIN connectors, PCB, 1/10" (2.54mm pitch)
10POLE connector, Cable, 1/10" (2.54mm pitch)
5POLE connector, Cable, 1/10" (2.54mm pitch)
Last doubt... for what is used those crimp terminals in the gssl project?
16pcs CRIMP TERMINAL for pcb connectors
the crimp terminals are needed for the connector, to fix the wire and the molex housing..
