Harrison Ford Filter Feeler
Looks like there are 3 versions of pots Colin sells.  Which one are you guys using?
OM-01-028 or RU-01-022 or OM-01-029?
UPDATE:
This is the one Marc recommends.
http://www.audiomaintenance.com/acatalog/om-01-028_extended_info.html
Also, for the bypass switch is it AL-03-001 or AL-03-002?  I'm honestly not sure if it matters as long as they are 2 POL and latching.
The:
2  50k Dual Lin  LOPASS, HIPASS  Audiomaintenance.com
I'm not finding it at audiomaintainace.. What's the correct component?
http://www.audiomaintenance.com/cgi-bin/ss000001.pl?page=search&PR=-1&TB=A&SS=dual+lin&ACTION=quick+search
G-Sun said:
The:
I think it's this one:
OM-01-028 - 16mm - 2 gang 47k rev. log
Part Code: OM-01-028
It's listed as 50k LIN in the BOM, but from what I know a rev.log works better in this application.
I'm also wondering wich switch to use. Is it this one ?:
AL-03-002 - 2 Pole Changeover Switch (PCB Mount) - Latching Miniature
Part Code: AL-03-002 ??
MrZpliff said:
G-Sun said:
The:
Ok, thanks! (Don't know about that switch)
dandeurloo said:
marc, which switch did you use for the bypass?
http://www.audiomaintenance.com/acatalog/AL-03-001_extended_info.html
The pins didn't QUITE line up, but with a little squeeze they fit fine.
Colin says the 1/4 shaft pots DO fit on the boards. Would you guys prefer 1/8" or 1/4" shafts? Does it make a difference to anyone? We're gonna have to get some pretty small knobs to be able to grip them anyway. The pots are right up next to each other.
no idea on knobs.  It would be nice to use something like on dbx 160's or SSL's.  Something that can have 2 different colored caps.  1 color for the HP and 1 for the LP.  Anyone have a good source?
I'm an idiot, those pots have 4mm shafts, not 1/8". I don't think those knobs are going to fit. Maybe it does make more sense to move to the larger shaft size....
Working on it.
Beat me to it Jens
Okay, I think it's a wise move to switch to 20mm pots with 6mm shafts. That way we can use standard 1/4" knobs. The 4mm knobs seem to be damn near impossible to source in the US.
Dan: That will mean the pots are going to have to move slightly on the faceplate. Let me know what info you need and I'll track it down.
