??? I'm looking at the board and following traces it seems to be correct on PSU board and Main board, only the 7815 is not written on PSU pcb for VR5 positive Reg.
Thanks Zayance,zayance said:??? I'm looking at the board and following traces it seems to be correct on PSU board and Main board, only the 7815 is not written on PSU pcb for VR5 positive Reg.
jandoste said:Any body has any reference for EAO pushbuttons( Farnell) ?
baadc0de said:Oh, so http://www.audiomaintenance.com/acatalog/EA-03-001_extended_info.html this one then?
Igor said:Great news about MixBuzz1!
We shipped Dec 12th-21st orders at Dec 21st.
I had very busy week, sorry. Saw some support threads needs an answers,
will have a time for this tomorrow.
I found more than enough info here:Something to do to use 4x2180? Pin 4 lifting trick?
.Any clues on how to implement/calculate CR1, CR2, RR1 and RR2 for the Release ?
By ear, take potentiometer and capacitor or 2 pots and 2 caps.
Logically, for 0.9 sec setting release, (between 0.6 and 1.2) use 750 or 820k and 0,47uf.
Rolls music increased a bit maximum release (last setting) and did
"dual release" push-button instead of A setting.
Don't affraid to experiment
- on C&B RV_1| RV_2 | will have 100r ? if I use all options (SC-MIX etc etc)
[/quote]- Do I must put Ratio's 500r Trim pot ? if I use all options?
Really frequently asked question- R6L and R6R TBD ?
2 TBD 1/4W METAL FILM 1% R6L, R6R ! INSTALL 0R WITH REPLACEMENT BOARD
! DEPENDING ON VCA USED, VALUES SHOWN FOR REPLACEMENT BOARD WITH 4X2181
RESISTORS INCLUDED FOR 3 BUILDS:
DBX202X
R6=3K74, R3=4K99, R100=909R
REPLACEMENT BOARD 1XVCA
R6=JUMPER (0R), R3=20K0, R100=909R.
REPLACEMENT BOARD 4XVCA
R6=JUMPER (0R), R3=4K99, R100=909R
Igor, I didn't receive 360k, 750r0, 470k, 200r, and just I got one 2k4! I got a lot resistor M
On the main board PS is,
1 /-15V
2 /+15V
3 /-18V
4 /+18V
5 /AGND
6 /AGND
7 /-12V
8 /+12V
9 / Case
But on PSU board not the same ?
Hopefully, yes.Oh, so http://www.audiomaintenance.com/acatalog/EA-03-001_extended_info.html this one then?
BAG12 DBX202X REPLACEMENT BOARD
ALL COMPONENTS FOR 2XVCA REPLACEMENT BOARDS (SINGLE 2181 VCA)
SPARE RESISTORS FOR 4XVCA UPGRADE INCLUDED
2 22...47 PF CERAMIC CAP PITCH 5MM DON'T USE WITH OPA604 AT PLACE OF IC9
CAPACITOR-POLY', 5MM PITCH, 50-63V
2 0.1UF C5/2.5 C44
RESISTORS
8 5K1 1/4W METAL FILM 1% R9, R10, R11, R12
8 20K 1/4W METAL FILM 1% RI1, RI2, RI3, RI5
2 100R0 1/4W METAL FILM 1% R102
2 732R0 1/4W METAL FILM 1% R101
IC
2 THAT2181B U$2, U$3, U$4, U$5 #1354172 ETC
2 NE5534 IC9
jandoste said:Did anyone already got this switch? [for the Mix] I didn't receiev it and I finished my farnell list just I need to know what is it exactly? I searched in docs_v2_4 2 but didn't find it!
