Hola Igor,
is it right? on the picture, red wire goes to ATK 1, black one is ATK 2
But on "wiring diagram" picture is not same ?
Hey Umit!
The electrons doesn't care what is the color of wire.
Just go with wiring diagram. I can post wiring diagram and help with troubleshooting,
but hey, you have to so some homework as well.
If this diagram is not comprehensive enough, just write, will try to represent it in other way.
I had some very busy days, sorry, now passing on emails etc.Sorry if I am bothering you with lots of email, but I am not getting any
feedback from you and I am wondering if you receive them at all?
Of course. We will work this out.I'm Building MIXBUZZ kit with MATA_HAZE here in Italy, he will send you an email with all the missing components from both our kits.
Would you be so kind to send them all to my address ?
If somebody have missing components, please send me the list to email.
Please check the docs, Control_sidechain:ANyway, we have a question regarding the RATIO:
can you confirm that the plug in board will give the compressor 6 ratio settings like on the one in your pictures? 1.5,2,4,6,8,10.
There are 3 ways to stuff the RATIO board. Default is 1.5-2-4-6-8-10.
Please check the files: front_btm.png
All parts for full ratio option are included, resistors-bag5 of basic kit, the rest (switch, diodes etc) in basic kit as well.
I would like to add the standard compression meter (8027-B Meter from Hairball) to the kit. Can this be done? Specifically,
can I drive BOTH meters at the same time. If not, can I have the G.R. switch to the meter? Thank you, David.
Please download Corel file with front panel stuff, it located with the other documentation for MixBuzz1.
PCB outlines etc are on layer "Centers". You can play with front panel layout, just check everything fits fine.
I sure it is possible to fit small Behringer GR meter at the left side. With some squeezing, 8027
(or Sifam AL19) should fit as well.
