mata_haze said:Hello Everybody,
my unit is nearly finished I only have one problem and I hope someone who has finished the unit could give me some read-out.
unit passes audio,makeup works but no compression.
I have checked the Threshold pot is wired properly (I get a swing of + and - 12V at the wiper) and the RAtio and attack-release pots are ok.
I have carried out the following measurements:
on IC3 on both PIN 8 and PIN 14 I have the following: (DC)
RATIO Voltage Swing
1.5 3 - 17 mV
2 203 - 216 mV
4 no swing 156 mV (fixed)
6 361 - 362 mV
8 380 - 381 mV
10 391 - 392 mV
on the same Chip (Ic3) I have a swing of 5 to 150 mV on PIN 1 and 7. (DC)
I am trying to figure out were my mistake lies I can see that the DC voltage runs all the way from the wiper of the threshold pot to PIN 1 and PIN 7 of IC3 and then it gets "messy" on PIN 8 and 14, also no DC after the diodes D6L and D6R.
also the makeup works fine so IC5B it's ok.
I am using IGOR's mod to implement a continuos pot for attack and release, so I am not using the stepped lorlin.
any help (and/or measurements from working units) will be VERY much appreciated!
Mattia.
mata_haze said:Sfter further investigations I have found out that the sidechain signal stops before hitting the detector.
I can trace the a sinewave (1V RMS) up until the left side (looking at schematics) of R14L and R14R and then it disappears.
by checking TP1 and TP2 I found out there is no sinewave there either.
I am assuming the VCA works in a "current fashion" rather than voltage and then IC1A and IC5A then convert the current into voltage again hence the TP1 and TP2 afterwards.
can anyone comment on this?
I am not sure what the " - CONTROL " and " + CONTROL" means on pins 5 and 7 of the VCA, are they not just supply +-15 VDC? or should I expect some signal there too?
EDIT: I have +15 VDC on pin 7 and -15VDC on the 5k1 resistor attached to pin5. there is -2.85 Vcc on pin 5 of the VCA.
Mattia
piano said:Does the switch get placed this way?
