piano said:FOR USA SOURCE - EAO SWITCHES - POWER & BYPASS SWITCHES Are these the correct switches and will they fit one over the other in a 1 rack unit?
---EAO 01-281-025 SWITCH HERE $24.12 http://www.newark.com/eao/01-281-025/switch-pushbutton-dpst-1no-1nc/dp/30B3689
---You can get the lenses HERE (red) $1.98 http://www.newark.com/eao/01-951-2/lens-square-red/dp/91B2351?Ntt=91B2351
---and HERE (white) $2.16 http://www.newark.com/eao/01-951-9/lens-square-white/dp/66F9722?Ntt=66f9722
However Igor, what lamps do I use? 12 Volt or 24 Volt or something else?
---12 Volt HERE http://www.newark.com/eao/10-1109-1329/lamp-incandescent-slide-12v/dp/76K1087?Ntt=76k1087
---24 Volt HERE http://www.newark.com/eao/10-1112-1279/lamp-incandescent-slide-24v/dp/76K1088?Ntt=76k1088
briomusic said:Just wanted to say I got my mixbuzz up and running with pretty much everything working well
Few problems left to deal with:
Meter in IN and OUT modes only shows signal applied to the right channel, but on both bargraphs. What could be causing this? (When calibrating I also noticed that only the right-hand Offset and Range trimmers had any effect on the LED meter.)
S/C HPF settings 40Hz and 80 Hz behave the same, will have to look for solder bridges I guess. :
One more question is it safe to operate the Mixbuzz with the meter driver board detached? I had to do this to get to the C&B trimmers located underneath, and noticed the PSU getting a lot hotter (all LEDs lit on the disconnected LED meter)
INA137PA ..... it's ok to use them
ELMA's for Threshold and MAKEUP: can you give us the resistor values to use with your pcbs
Duh.... Hopefully, no missing parts anymore.we've received all the IC's.
Of course. It is same specs line receiver; sound-both are very clean; THAT has laser-trimmed resistors and can be used in MS matrix...1. In the soundpath you say THAT1246 for IC1L, IC1R , but you have sent us INA137PA ..... it's ok to use them ??
2. We are going to use ELMA's for Threshold and MAKEUP: can you give us the resistor values to use with your pcbs??? We have to use 21 positions, right?
jandoste said:Hi Igor,
I did my first calibration and I have much more sound to the left than the right (1left +2 right side )
on the ratio board I used 1m2 instead of 1m5 ??? and I got problem here I get some distortion with the ratio pot,
with ratio;
- 1,5(dist)
- 2(dist)
- 4(dist)
- not with 6
- 8 and 10(dist)
any idea?
jandoste said:jandoste said:Hi Igor,
Bump
