Matt Nolan
It can be useful when bringing up power supplies and checking internal mic connections, if you can find an old plug that is the same pinout as your valve, to solder up a dummy tube with it - high wattage resistor for the filament and lower wattage resistor for the anode-cathode path. Otherwise, just do lots of probing of voltages at every step of the way.
